Status
Not open for further replies.
1 - 4 of 4 Posts
I programmed some buttons on the pronto to control winamp, but the same button sents out different ir code each time i press it, am i doing something wrong.
Are you using RC5 ?? I know that RC5 can be tricky sometimes (though I am using it fine so ???) at Rx....
Simple solution is to switch to RC6 that seems to be more reliable from what I have read...
1 - 4 of 4 Posts
Status
