Hopefully somebody can help me.
I just got my refurb S4 mounted on my ceiling ~14 ft from my screen (distance is midway point of range as per the throw chart on Marantz's and the owners manual's chart) and I am projecting onto a Carada 16x9 92" screen. There was some question as to which lense I had received in my S4 since the case of the PJ was white, but after having Marantz look up the serial #, I have the VP12S4S, 'S' at end is for 'Standard' lense, others have referred to as the 'Medium throw' lense. Long story short, the PJ is mounted the correct throw distance from my screen as far as I can tell.
I am in the process of trying to dial in the settings/setup of the PJ, and for some reason, I cannot get the intial non-sourced blank-screen image to shrink down far enough to fill out the screen perfectly, there is about a 1 foot overlap on all sides. The manual zoom dial on the lense is zoomed in as far as it can go. I can change the aspect ratio, shrink the picture down, etc, to make the actual picture image fit my screen, however, there is still the area outside of the screen that is there, it is dark but visible. When I do the test pattern or when the menus come up, it then shows up very visable, of course, that the PJ is projecting outside of the screen. I have tried messing with all of the settings inside the PJ, but I cannot get the complete image to fit my screen??
Sorry if I am not using very technical terms to describe this, but I am a first-time owner of a PJ, and somewhat of a HD and HT newb.
Can anyone lead me in the right direction to fix this issue? If there is any questions that will help your answer, i can elaborate futher on what I have tried so far.
