Status
Not open for further replies.
1 - 6 of 6 Posts
I am using WinDVD 3 on a Windows XP system. It seems to me that my system ought to be fast enough to play a DVD all the way through without skipping, but no matter what DVD I try, I get random 'stuttering' (I think this is the right term) where the picture and sound will 'freeze' for 0.5sec or so and then continue on.
Sometimes I can rewind and see another hiccup in the same scene (but not exactly the same place) and other times if I rewind it plays through cleanly. I see this on every DVD I play (tried over 30). If I can't get this fixed I'll have to go back to my dedicated DVD player.
I am running a clean install of WinXP Home. (There don't seem to be any registry settings or control panel options to increase buffering on the DVD player like there are in Win98.)
Any suggestions or ideas will be greatly appreciated.
System Specs:
MSI K7T266 Pro2 mainboard
AthlonXP 1700+ CPU
256MB PC2100DDR DRAM
nVidia GeForce2MX400 w/ 64MB
SB Audigy w/ HoonTech daughtercard
Creative DigitalVCR
WD 100GB HDD (on Primary IDE)
Toshiba SD-M1612 DVD (on Secondary IDE)
Linksys 10/100 Ethernet
Antec TruePower 330 power supply
jdifonzo,
what driver version do you use for your audigy? I have a soundblaster live 5.1 and solved ,y stutter problems by updating to the drivers from the Windows Update. PM me if you need a direct link.
Also, are your IDE channels running under DMA? make sure they are by going to Device Manager.
check these things and come back to us if there are still problems
Try using Zoomplayer with a DVD graph that uses default waveout.
Directshow sound causes stuttering.
Discussion Starter · #4 ·
P3Animal, the IDE channels are using DMA. I am using the Audigy drivers that came on it's original install disk, and they are working and I am afraid to try to upgrade them because the last time I tried that the old stuff was left hanging and the machine would not boot and I had to do a clean install to fix things.
JackLT, are you saying that WinDVD is defective and I need a different software DVD player if I want stutter-free playback?
Thanks for the help so far... anyone else seeing my type of problem?
Does it seem right for this beefy machine to not play a DVD without stuttering?
1 - 6 of 6 Posts
Status
