I am getting my Onkyo TX-DS989 in 2 weeks time and need asistance in where to place my rear ex channels and also my current side Dipole rear channels.
http://www.chariot.net.au/~spizz/My%...%20Theater.htm
That link has how I have my speakers currently but I have read that my rear speakers should be 2-3 feet above the top of your head. Currently I have them at ear level. So should I raise them another 3 feet?
Lastly and more importantly the Rear EX channels and where to put them as I am going to use 2 speakers for EX. Ideally I think they are supposed to go in the middle of the entranceway in the 3 picture down. However as you can see that is impossible. Would there be a problem if I mounted the speaker to the right of that entrance where that Buzz lighteyear picture is? Or would that be to close to the side rears which would cause a problem?
Lastly should i use a direct radiating for the rear EX channel or Dipoles/Tripoles? Which is really conflicting as there are no direct radiating THX certified speakers as far as i know?
Any advice is appreciated.
Spero D.
[This message has been edited by Spizz (edited April 21, 2000).]
Spero D.
