Just picked up a new 3D LCD, an upgrade from my RPTV and finding my old Marantz SR-780 isn't going to cut it and looks like I need to sell it and upgrade. I currently have an old DVD player that only outputs S-Video, Wii, CD player, PS2, SA 8300HD cable box and my TV. I'm looking into doing a HTPC, so the CD player, DVD, and cable box would go away.
One thing I'd like to have is the ability to send music to my pool speakers. Currently the Marantz outputs to an old mini stereo for the multi-room. I don't know if newer receivers allow a direct connect of the speaker wire or if you always need a 2nd receiver, but would love to do away with the second receiver if I could.
Since I just took a hit on the TV and a HTPC will take away the other arm and a leg, I'm thinking the $300 range is about all I may have. I see the Pioneer VSX-31 at Costco and a Yahmaha RX-V567BL at BB within my budget. Will these work with my pool audio needs? Are there better options? I appreciate the help.
