I have a listening rm 18x36 w/8ftceilings..its located on one side of the basement.
Looking for help/suggestions on which components are more important to upgrade for a stereo system upgrade?
-I know I need to upgrade my speakers for my size rm i have some suggestions so I plan on doing that 1st.Bookshelf ones listed below might small so might need to get bigger/Tower speakers?any suggestions?
-TTable:is it better to upgrade from the 1 i have or get a Phono Pre Amp(does that enhance sound?) or get a new cartridge or just get a new TT (the ones listed below).
-Receiver:Should I just upgrade the receiver (listed below) and get an amplifier or integrated amp, pre amp don't know how they work/don't know differences, coulde use help there. Does either enhance sound and or which 1 carry's the most power I need were I keep my receiver?
Do I get receiver w/built in Amp, if so is that enough?
I listen to allot of vinyl and cd's.In vinyl listening I am looking for that nice clear/loud sound w/out spending $5k...want something that really enhances the vinyl (and cd's) sound that its meant to sound like.
I have a $1k/$1,500 budget no more then $500 on EACH components and speakers or I think speakers need the most $$, correct?
I currently have:
-Sony PS-LX300 USB turntable
-Technics SA-EX140 60hz/155w Receiver
-Bose 201 iv series
After researching stuff I was looking at these to get. What do you think and or do recommend something else?
1)-Turntable:
Pro-Ject III debut turntable or Music Hall MMF-5 or Rega P3
....Or keep my Sony turntable and just upgrade my cartridge and/or phono pre amp or dont do anything?
2)Also I am not sure what the Phono PreAmp(think thats what its called)does? Do I keep the TT i have and get the Phono PreAmp? Does the Phono Pre Amp enhance sound?
2) Upgrade my Receiver
-Yamaha A-S500......looking for a built in Amp for more sound in my receiver
or get an AMP (dont know 2 much about them) and keep my receiver?
3) Speakers..had a couple in mind:
-EPOS - ELS-8 BOOKSHELF SPEAKERS
-WHARFEDALE - DIAMOND 10.1 BOOKSHELF SPEAKER
-Usher S520
-Also what CD player is good to get under $500 that enhances the sound?
I currently have:
-Bose 201 iv series
1)-Turntable:
-Usher S520
