Help!....Remote codes needed!!!...
369 Views 1 Reply 2 Participants Last post by  MikeSRC
Hi Gang
I have a Lexicon MC-1 a Pioneer S-201 laserdisc player and a Sony VPH 1271 Projector. Would anyone have any idea what the 4-digit codes might be for these devices, sure would save a lot of cloning!
I have the Kameleon remote.
Any help would be very much appreciated.
Thank you, Glenn
Status
Not open for further replies.
1 - 2 of 2 Posts
If the codes in the manual don't work, you might want to try calling One for All (or Radio Shack depending on which Kameleon you have) and have them upgrade the remote through the telephone. That's your best bet since the Kameleons are only able to learn about 20-25 commands.
1 - 2 of 2 Posts
Status
