Status
Not open for further replies.
1 - 7 of 7 Posts
I have not used any satellite system so I really know nothing about what I supposed to be looking for when I shop for DirecTV.
#1 - I want to get an HD box - leaning toward new Sony HD300
#2 - I really only need one other receiver (maybe 2). What receivers are they giving out with the free packages?
What should I be looking for as far as purchasing a system. What dish? Any secrets to getting an HD box as a part of a package deal with free install etc.
Locally the big chains I have are Best Buy, Circuit City, Sears.
Thanks for any help!
You could always get a free 2 room setup from BB or Circuit City or the likes
(and maybe get a gift card rebate too) and then after you're a customer for
a month or two, call DirecTV and ask for Customer Retention and try to get
them to give you a $100 or more credit on your bill in exchange for you
buying the $399 HDTV deal that they're running. That gives you HD at
$299 effectively.
I suggest waiting until the HD Tivo box is ready. Supposed to be Q1 of next year. This should be a winning product.
Last I read on this forum was specifically March, and that it will likely to be even later.
I don't like buying first generation products; I bet next fall they will release the second version, just speculating, though. But if you like being on the leading edge of technology, go for it.
Discussion Starter · #5 ·
I do not time shift on my HDTV - primarily just in the bedroom where my old Replay would work with a regular receiver. Also don't want DirectTiVo if won't archive (firewire).
I see lots of 2-3 dish free deal. Do any retailers allow a credit for 1 of the normal receivers to get the HDreceiver?
One regular receiver wouldn't really have that much value as the 'free'
setup ones are really low end basic receivers. I know that doesn't answer
your question specifically, but might help.
Besides, I talked to a couple local retailers and you won't get them to give
you an HD box (let alone the Samsung T160) for $345 total including the
oval dish and installation. Even if they can offer you DirecTV deals like the
$399 HDTV deal DirecTV has on their website right now, the local retailers
won't have the price adjusting ability of Customer Retention through
DirecTV.
I guess what I'm saying is if you find a local retailer that will swap one
standard box for an HD one and charge you only $300-$400, you're doing
really, really well. :)
1 - 7 of 7 Posts
Status
