Hey what's up guys, I'm new to these forums but I lurk here at times whenever I need some simple av answers. But lately, I've been wondering what to do with my next issue.
Behind my wall-mounted HDTV, there is a hidden pipe behind the wall made specifically for cables to run through. The problem is that the inner diameter of that pipe is 7/8" thick, which is extremely thin. As of right now, I am only running a coaxial cable for the cable box since no other cables seem to fit otherwise.
I simply only need three cables to run through that pipe: HDMI, coaxial, and optical (toslink). I'm having a difficult time finding an HDMI cable with a head that's thin enough. I've already ordered a thin coaxial cable made by philips, and I'll most likely just get a regular toslink cable from monoprice.
I've definitely thought about cutting an HDMI cable, slipping it through with the other two cables, and reattaching it by resolder/heat shrink the wires as the cheapest solution. Tearing down the wall and replacing the pipe with a bigger one is not an option.
What do you guys suggest? I also think that HDMI through a cat5e/6 is too expensive.
