Hi All,
I am having a dilemma with a faux wall that has to be built to be the wall for the screen. The room will be 19' x 14'. Im planning 2 rows with a 130" screen. The projector is the Sony 4k.
If I sacrifice 2' from the depth of the room, I can get a fixed screen with side mounted speakers. If I want to add 2' to the 19' to make a total depth of 21', I need a drop down screen.
Do you sacrifice quality with the drop down or space with the fixed screen?
Thanks in advance.
Thanks in advance.
