Hello all!
I hope I have the right forum! I apologize in advance if it's incorrect! Here's my issue. I have a LN46A950 and I've purchased the InfoLink WIS-08BG Lan adapter to connect to my network wirelessly. This all works flawlessly, the TV gets and IP address everything works on that front. It shows up on my router, and all the built in internet widgets work fine (like weather!).
The problem comes when I try to hook up Samsung's PC Share Manager. I've installed the latest version Samsung suggests for the TV (1.5) and the server is started and I have a folder shared. I click the share tab at the top and go into "Set Device Policy". here you need to "accept" the TV to gain access to sharing. But the TV never shows up. I've tried everything with my firewall and router and I just can't get it to show up. I've even disabled my firewall entirely (on the router and on Windows Vista). I've searched the web vigorously for a solution and the only problem I could find was if your PC was hooked up wirelessly as well, which it is NOT.
Has anyone run into anything like this? It's really annoying, I've spent so much money on all this and I just can't get it working at all! I've spent a week on it already.
Please if anyone knows anything to try it would be greatly appreciated!
Thank you for your time!
-Paddy
-Paddy
