Help Sanyo DP42848 inputs?
800 Views 2 Replies 2 Participants Last post by  jbbcd
Hi,
Just bought my first HD (the price was right, I'm cheap!) Sanyo DP42848.
Everything is working fine untill I want to plug in my sons Frogger game from Wallmart
My set up is as follows,
1) HD cables from cable box to HD inputs on TV.
2) Non HD cables from non HD Tivo box to Analog inputs on TV
My problem is there is only one more place for inputs on the TV & its for HD cables only.
So where if at all can I plug the game in so my son can play?
I don't want to have to pull the TV out of the built in wall every time he wants to play.
See less See more
1 - 3 of 3 Posts
You just need a simple composite A/V switch to connect multiple sources to the same input on the TV, such as this one, which can accept up to 4 sources, and comes with a remote control.
http://www.buy.com/retail/product.as...27&dcaid=17902
Hope this helps.
Matt
1 - 3 of 3 Posts
