The info on my setup:
Receiver is Onkyo TX SR608
SETUP 7.1 System 14'x8' Room
FRONTS L/R
RB-61 II Bookshelf Speakers (pair)
http://www.klipsch.com/rb-61-ii-bookshelf-speakers-pair
FREQUENCY RESPONSE: 45Hz-24KHz ± 3dB
HIGH FREQUENCY CROSSOVER: 1500Hz
HIGH FREQUENCY DRIVER: 1" (2.54cm) Titanium diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
LOW FREQUENCY DRIVER: 6.5" (16.5cm)
NOMINAL IMPEDANCE: 8 ohms compatible
POWER HANDLING: 100W RMS / 400W Peak
SENSITIVITY: 95dB @ 2.83V / 1m
CENTER
RC-42 II Center Speaker
http://www.klipsch.com/rc-42-ii-center-speaker
FREQUENCY RESPONSE: 88Hz-24KHz ± 3dB
LOW FREQUENCY DRIVER: Dual 4" (10.2cm) Cerametallic cone woofers
NOMINAL IMPEDANCE: 8 Ohms compatible
POWER HANDLING: 75W RMS / 300W Peak
SUB
Omni S8 Subwoofer
http://www.miragespeakers.com/na-en/...i-s8-overview/
System Type Powered Front firing Subwoofer with Down firing port
Frequency Response 27Hz-120Hz
Amplifier Power Output 100 Watts RMS, 400 Watts Dynamic Power
Woofer 8" woofer with ribbed elliptical surround
Variable Low Pass Filter Yes
Inputs Low Level, Stereo High Level (Speaker Level)
Overall Dimensions cm: 37H x 30W x 39D
Weight 29 lbs. lb / 13.4 kg
Finishes Black
UPC 629303-13645-4
Part Number 13645
SURROUNDS
Cerwin-Vega! VM-5E
http://www.cerwinvega.com/home-audio...ers/ve-5m.html
1.After Audyssey do i set all speakers to 80HZ ?
2. Do I crank Intelvol to +12 (reason reciever sounds week not enough volume)
3. Do I turn on Dynamic EQ also Re EQ ?
FRONTS L/R
CENTER
SUB
Omni S8 Subwoofer
Finishes Black
UPC 629303-13645-4
Part Number 13645
SURROUNDS
Cerwin-Vega! VM-5E
