Hi All,
My current system consists of TV: Panasonic TC-P58VT25, Receiver: Pioneer SC-75, Speakers: Vienna Acoustics Front L/R - Mozart Grands, Center and Rear L/R are Waltz Grands (Until I can find a deal on a Center Maestro and extra Waltz to make a 7.1 system) Sub woofer: Rel T2 I have my speaker distances input into the receiver and ran the auto calibration it set all my speakers to small with Cross over at 100Hz I bought a SPL meter from radio shack to try to get everything reaching the listening area at the same level.
My questions are 1. How do you determine if a speaker setting should be large or small, 2. I read the SPL levels for THX should be 75 but I do not know at what volume the receiver should be to start with before adjusting the level settings. 3. Can anyone suggest a good site on calibrating the setup with a SPL meter that is simple to understand?
Thank you in advance.
P.S. I was running this setup on a Denon 891 receiver till yesterday which is only rated at 8 Ohms instead of the needed 4 Ohms for the Vienna I have to say while it did not drive the speakers with the punch they should have had I was VERY impressed that the Denon did run them with out over heating and shutting down.
