Please help me set up my new Panasonic PT-L500U.
Is there is a "flicker" adjustment and if so how do I access it?
What settings are you using for your 500U? I hope to use an AVIA disk soon but until then I'd like to try improving the PQ.
I'm using component cables with a Panasonic RV32 DVD player with the out of the box (normal) settings on the 500U.
I watched part of a movie (Galaxy Quest) last night and saw vertical banding before the movie started, but very little during the movie. My biggest concern is the SDE I was seeing anytime a character moved, especially on close-ups. I used a 7' diagonal screen size and viewed it from 11', which I'm expecting should be fine. I think the DVD was showing in 525i but I forget the exact number.
Thanks for your help.
