Status
Not open for further replies.
1 - 2 of 2 Posts
Hi all:
I am finally having my NEC 135lc set up... We are having trouble setting the jumpers for ceiling mount..
I had set up the projector for desk/front now we are setting up for ceiling front.
we are getting message:
Warning Incorect H Plug Polarity
Can anybody tell us how to do this?
Where is th4e H Plug?
Any suggestions appreciated!
Mark
Hi Mark,
I'll explain this as if you are standing behind the projector, looking at the deflection board, with the lenses pointing away from you........
The 3 connectors shall be located as far aft as they can go, on the pins. The Blue wires will be closest to the lenses, the Red wires will be aft.
The dummy plug will be mounted on the row of pins closest to the lenses, spanning across the 3 rows of pins that the Hor defl connectors are on.
The 3 rows are labeled EB, EG, ER.
Don't forget to go into "adjust" "option" then "setting mode" and set the projector orientation to "ceiling/front"
Hope this helps....Drew
1 - 2 of 2 Posts
Status
