1 - 1 of 1 Posts
I was looking into building a tall >40" cab for a vented sub. I can calculate that the box will have a resonance at ~175Hz but the box sim i usually use ( UNIBOX ) does not calculate the how it affects the response. Nor does it calculate how different placements of the woofer might affect the resonance. I was thinking the worst place might be in the end of the box, like in a sono type box. A better placement might be right in the middle, but i am not 100% sure and i dont know how to sim it. Is there any free software that can do this or is it commercial software only?
Maybe Hornresp can do it?
1 - 1 of 1 Posts
