I have 4 TV receivers. 1 Samsung HD DirTV box, 1 two-line Tivo box (one line goes direct, the other through a multi-switch), and two standard DirTV hughes boxes
I am having some wierd glitches. I am getting the periodic "searching for satellite signal" message on every box going through the multi-switch, I am getting total signal dropout on the Samsung for 1-3 seconds. Sometimes more frequent, and then total loss of signal. The installer comes back, replaces the multi-switch, it works for awhile, then the same thing happens. Another wierd clue. When setting up the Tivo box, the signal is very strong from all three sats on all three transponders (ABC) for sat1 and sat2. But when it does the setup, it fails on transponder b and c saying "not detected", but only on the line going through the Multiswitch. The direct line is fine. I was told by my installer that the Samsung boxes are defective and is sending a charge that burns out the multi-switch. So I returned the Samsung box and exchenged it for a Hughes DirTV HD with HD recorder. I have now replaced the Tivo and Samsung boxes, LNB, and about 5 multiswitches.The installer is here and we are still finding problems. The new HD Tivo box is showing the strong signal on sat 123 on ABC transponder, but upon setup, fails saying transponder b and c not detected.
Whoever solves this mystery is my hero, and has my undying gratitude, as nobody can figure this problem out. HELP!!!!!!
