1 - 4 of 4 Posts
The ZP120 is rated at 55 wpc into 8 Ohms. The Ascend Sierra-1 is 87bd sensitivity. Will this be enough power?
I am getting out of the hobby of equipment and back into the hobby of music. I don't need reference levels. I just want good quality music with a ton of convenience.
Anyone using the amp in the ZP 120 with speakers of similar specs?
Discussion Starter · #4 ·
Originally Posted by buzzy_ /forum/post/16925724
You'll want to describe the layout of your room some ... how big a room, how far away will you sit.
it is a smaller room. a combo living room/dining room in a town home. I will sit probably 10 feet from the system.
1 - 4 of 4 Posts
