Status
Not open for further replies.
1 - 1 of 1 Posts
When I start the procedure for the registration adjustment of my 1252 with the green tube, the top and bottom line of the hatch pattern is curved (not square). According to the manual I should use the PIN key in order to do the horizontal line adjustment.
But this key works on the green tube only for vertical line adjustment; for horizontal line (top and bottom) when I press the key I modify the numbers but with no effect on the pattern.
So the bottom and top lines of the starting green pattern remain curved and I'm forced to converge the red and blue tube with the "curved" edges of the red image.
Where I'm falling in wrong ?
Cioci
1 - 1 of 1 Posts
Status
