Help! Sony LCD or Panny DLP - Connectivity to PC
249 Views 1 Reply 1 Participant Last post by  ojman
OK...I have quite a saga to go through and would really appreciate any help I can get. I have narrowed my HDTV choices to the Panasonic 50" PT-50DL54 DLP and the Sony GW 50" KF50WE620 LCD RP. I really like the picture quality of the Sony better and it's on for an amazing deal right now, but I can't get past one issue. The connectivity of my notebook and the lack of connection points on the Sony. I have tried buying a VGA cable and a VGA-DVI converter so that I can connect my notebook, but apparently there is a difference between the type of DVI connection on the Sony and the type of connector I would need. (There were 4 extra pins on the DVI connector I bought when compared to the Sony's connector). In addition I have heard all sorts of horror stories surrounding this Sony's difficulty with PC connectivity. If someone could give me a step by step of how to set up my PC with this Sony, I would go and buy it today! I don't fully understand some threads I have read about tweaking the service menu as some PC's appear to work OK without doing this and some don't (dependant on Video card). I am really at a loss right now on these TV's because of this conundrum - it comes down to Picture Quality vs. Connectivity. I did have my Notebook hooked up to the Panasonic and was dissappointed that even though I have a widescreen laptop, I can only get a 4:3 screen on the Panny. My other issues with the Panny are that it is priced a touch higher and the replacement bulbs are almost 2X's as much as the Sony's. Please help as the Sale ends on the Sony on the 28th!!
Here is a listing of the equipment that I am planning on using:
- Toshiba Satellite P10 with Media Centre
- Nvidia GeForce GO 5600 with S Video and VGA outputs
Please help point me in the right direction.
Status
Not open for further replies.
1 - 2 of 2 Posts
Does anyone have any input on this...I just need someone to give me the confidence that this can be done so that I can buy the Sony while it is still on sale. Is this possible without major tweaking? What sort of connectors will I need to make this happen? Should I just suck it up and buy another TV that has decent RGB inputs like a Samsung DLP? I definetly want to be able to see my computer screen on the HDTV in widescreen. It's pretty cheesy in my mind to have a widescreen laptop shown in 4:3 on the HDTV.
1 - 2 of 2 Posts
Status
