Status
Not open for further replies.
1 - 7 of 7 Posts
I need help setting up my surround system... It consists of
100W Left Speaker
100W Right Speaker
100W Centre Speaker
100W Left Surround
100W Right Surround
100W Subwoofer
*this is RMS*
I'm extremly new to this whole audio thing and based upon the attatched diagram i'm curious where the best place would be to place my speakers as well as my bed for the best possible sound
Headphones.
I second the above post. That seems the most logical. I would recommend using drapes or something like that since tv/monitor would be across from window and to reduce reflections off the windows from my mains.
I have a similar set up. Presently the fron and rear speakers hang from the ceiling. I am upgrading to plasma and wish to move the front speakers lower and put them in the cabinet. Is lower OK for the fronts?
NOOOOOO! Front speakers always sound best when stuck to the ceiling. (I'm kidding, I'm kidding.)
Actually, unless they're in-ceiling/on-ceiling models, it would be a very good idea to lower your front three speakers. The closer you can bring them to ear level, the better.
However, putting them in a cabinet is not a good idea because the internal reflectons can muddy the sound from the speakers. Is there any way you can mount the speakers on the wall around the plasma?
Best,
Sanjay
1 - 7 of 7 Posts
Status
