Status
Not open for further replies.
1 - 1 of 1 Posts
Hi. I have a DBS problem that is driving me up the wall.
Mits SR-HD DBS recvr.
wasn't getting any signal on it, and I figured out the multi switch was bad, so I bought a new dish, with an integrated switch and 3 LNB setup.
Aligned it with a Steren dual LNB sat meter with teh 22KHz tone, and got it dialed. (High 80s -72 with the LNB's locked)
ran off the roof, excited that I would finally have my HD back after 3 months with out it (too much work)
No signal on 101 or 119, signal on 110.
So I went back up on the roof, plugged in the sat meter, and the signal was cycling on both LNB's from 87 to 74. This was without any regular frequency. I checked the voltage on the receiver, and it was cycling from 19v to 12v.
I wasn't sure if this was normal, so I plugged in an old RCA, and it did the same thing.
No matter what I do, I get a great signal on the meter, but nothing on either receiver. I reterminated the cable on both ends as well.
Does anyone have any idea what mght be going on?
Thanks in advance, I'm getting sick of climbing the ladder.
1 - 1 of 1 Posts
Status
