1 - 8 of 8 Posts
I have a 20 inch samsung tv and have had it for about 8 months and just a few days ago I was watching a movie with my Philips DVD player that is about the same age and notice a white pixel right in the middle of the screen. Its only there when I use the dvd player but when I hooked the dvd player to my other tv its not there. So is this being caused by the tv or dvd player and is there anything I can do about it.
There is no such thing as stuck pixel in CRT TV. If you have a LCD TV go to the LCD TV
section in this forum.
I know this is an old thread but I have the same issue.
Philips progressive scan DVD player through component produces a white dot in the middle of the screen. (Not visible with other sources - TV is a Sony Wega 30" KV30HS420)
I know CRTs shouldn't get stuck pixels but any ideas what is doing this or how to fix it? Thanks
In both cases... it must be the Philips DVD player. Get a different DVD player (or borrow one?) and see if the problem is resolved.
Thanks! I'll try that tonight. I was kind of thinking (and hoping) it was the DVD player after I posted and thought about it more since all the other sources seem ok. (But, none of them are using the component inputs) I kinda thought it might be component input specific but that would be strange. We'll see what happens tonight with it.
Thanks again
Yeah... seems kind of strange that you and the OP both have the same symptoms and the only thing in commom is a Philips DVD player.
Good luck. Hope it works out.
Well just before returning the player I decided to switch the component video inputs to the other set of component inputs on the TV... It's fixed. I didn't try switching back to see if just those inputs were bad. Maybe tomorrow I will.
1 - 8 of 8 Posts
