1 - 3 of 3 Posts
· Registered
Finally got my Yamaha RX 2700 in. I spent the entire day hooking everything up and getting things configured.
After it was all up and running I noticed no Bass what so ever. I Swapped out the Audio Cables (Normal RCA type patch cords). Still nothing. I then spent 12 hours going in and out of ever Menu still nothing. I then Hooked up the SUB Pre out to the audio in on my TV, presto I had bass comming out of my TV speakers. When I hook it back up to the sub ...nothing. Any ideas the sub is a brand new SVS PB-10 just out of the box. The light turns green on it as well. Thanks in advance!
· Registered
Sounds like one of two typical things. Either you have selected "no" for the sub in the speaker setup menu in the Yammie , or, You have selected large speakers for the fronts. Set the fronts to small and set the crossover accordingly in the Yamaha(80hz or where ever you need it) and you should be good to go.
1 - 3 of 3 Posts
