Of those two choices id get the PB1000. It has deeper extension and a more reliable amp. Nice small space you have there should suit that sub nicely.
Guys, this PB-1000 is awesome! Much better than my previous sub, Klipsch R10SW. Its not a fair comparison but its the only reference i have for my room.
The bass fills everything with pressure and precision. Maybe the best sub i ever heard.
But something is bother me. Maybe some of you can help me with.
During Audyssey calibration process the sub volume is too LOW, you almost cant hear it even with sob volume dial set to 75%. The final results set que sub volume on receiver at +8.5db. As a comparison with the previous sub, Audyssey set the receiver sub volume at -12db with 50% of sub dial volume.
Do you know what im doing wrong? Or it how it should be?! Is this sub less sensitive than klipsch resulting on this low volume during Audyssey calibration?
Thank you once and sorry for my bad english. Hope you all can get it.![]()
Not sure how much of a difference the PB's gain structure is to other subs, but in that small space with it set at 75% having a return of +8.5 on the trim sounds way off. Either in a major null possibly an amp issue in the sub. I've read SVS likes their gain up higher so as mentioned max it out just to see what the trim comes back at. Hopefully your sub is just in a bad location. Have you tried a sub crawl yet?Guys, this PB-1000 is awesome! Much better than my previous sub, Klipsch R10SW. Its not a fair comparison but its the only reference i have for my room.
This sounds a bit odd. Try what others have suggested in turning the PB1000's gain up. You should be able to get a decent output past the 12 o'clock position. The most I have experimented with mine is around 2 o'clock and that is too much.During Audyssey calibration process the sub volume is too LOW, you almost cant hear it even with sob volume dial set to 75%. The final results set que sub volume on receiver at +8.5db. As a comparison with the previous sub, Audyssey set the receiver sub volume at -12db with 50% of sub dial volume.
I have a PB-1000. Before starting the calibration, set the gain to max so that when you start the calibration, it says that the subwoofer is too loud and asks you to adjust it until the on-screen meter reads ~75dB. When you get that screen, adjust the gain until you get a reading of ~80dB. I know that is above what you are being asked for, and it will show that it's too loud, but just continue with the calibration. After the calibration, let us know what it set the subwoofer trim to in the test tones section. Ideally you want it to have set the trim somewhere between -10 and -11.5. Then you can increase the trim by 5-6.5dB and still only be at a trim of -5 (it is recommended to not have a trim higher than -5 for the subwoofer). If you reach -5 and the bass isn't enough for your taste, increase the gain on the sub to taste.Guys, this PB-1000 is awesome! Much better than my previous sub, Klipsch R10SW. Its not a fair comparison but its the only reference i have for my room.
So, even with 100% on sub dial i barely hear it!bring up the gain on the subwoofer until Audyssey sets the levels around -11dB to -9dB
I dont have different possibilities for sub position. Its on the same place where i set the Klipsch.Not sure how much of a difference the PB's gain structure is to other subs, but in that small space with it set at 75% having a return of +8.5 on the trim sounds way off. Either in a major null possibly an amp issue in the sub. I've read SVS likes their gain up higher so as mentioned max it out just to see what the trim comes back at. Hopefully your sub is just in a bad location. Have you tried a sub crawl yet?
Yes, i tried with 100% of sub dial and barely heard it. I set the Klipsch back and with 50% of dial sub is much louder than my SVS.This sounds a bit odd. Try what others have suggested in turning the PB1000's gain up. You should be able to get a decent output past the 12 o'clock position. The most I have experimented with mine is around 2 o'clock and that is too much.
Also, I have recently had an issue of a bad Audyssey mic. The mic had gone and I could never get proper levels. I do not think this is your case, but just to be sure, see if you plug your Klipsch sub back - in the same position PB1000 is now - whether Audyssey detects it properly.
Yes, as i told before on this quote. They are in the same position. Thinking about the factory reset.As mentioned confirm if the PB1000's driver is in the same location the Klipsch's was (same distance from the wall) when you ran audyssey. Last time i was having problems with Audyssey (in my Integra AVR) doing a factory reset fixed it and bass was back, so maybe give that a try. Good point on the mic that can be confirmed by running audyssey with the Klipsch once again with it's driver in the exact location it was in before. Now this is just to experiment as subs with different port tunes can have different results in the same location.
If no improvement with trying "all" suggestions mentioned,,, give Ed Mullen a call at SVS USA as he knows everything about your new sub and may have more to offer.
So, my receiver is the Denon 2400 with MultiEQ XT and i does not have this options to fix the sub volume before Audyssey procedure. Its only available on MultiEQ XT32 witch is present on Denon 3X00 series and above!I have a PB-1000. Before starting the calibration, set the gain to max so that when you start the calibration, it says that the subwoofer is too loud and asks you to adjust it until the on-screen meter reads ~75dB. When you get that screen, adjust the gain until you get a reading of ~80dB. I know that is above what you are being asked for, and it will show that it's too loud, but just continue with the calibration. After the calibration, let us know what it set the subwoofer trim to in the test tones section. Ideally you want it to have set the trim somewhere between -10 and -11.5. Then you can increase the trim by 5-6.5dB and still only be at a trim of -5 (it is recommended to not have a trim higher than -5 for the subwoofer). If you reach -5 and the bass isn't enough for your taste, increase the gain on the sub to taste.
Yes. I have it but i need to use positive gains on avr otherwise the sub have almost no bass at all.Are you getting aggressive driver movement when playing bass heavy demo clips or is the driver movement minimal no matter what? If there is little driver movement with its gain maxed out then imo you have either a bad amp in the sub or your avr needs a factory reset. If the reset has poor results then SVS will send you a new replacement amp which is easy to replace.
Keep us updated after you have replaced the amp.even with 100% on sub dial i barely hear it
Started with my PB13's at noon for sub gain as recommended, and end-up around 8:30 (since they were way too hot post calibration). With a result of -8dB for the subs (all other speakers around -6dB), after the Audessey XT32 calibration. A good point to be, since this way you can increase your level from your AVR, after calibration to your taste.Not sure how much of a difference the PB's gain structure is to other subs, but in that small space with it set at 75% having a return of +8.5 on the trim sounds way off. Either in a major null possibly an amp issue in the sub. I've read SVS likes their gain up higher so as mentioned max it out just to see what the trim comes back at. Hopefully your sub is just in a bad location. Have you tried a sub crawl yet?
