Hi guys! So, here's the situation:
I moved into my house five years ago and spent 5 years thinking about my hot tub room. I finally got my budget and found a good contractor, but then at the last minute figured I'd save money over all if I did the whole basement at one time (less disruption in my life too.) So now I'm doing it all, including the "Home Theater." So I had 5 years to plan the hot tub room and five weeks to plan everything else, and I've been so busy planning things, talking to workers and running to stores to find fixtures, I never got to make this post to ask some specific questions. The walls are being framed, as I type they are banging under me! So I still have time for a few details I was hoping you guys could help me with!
First of all, the floor plan...
The theater ends up being 17' 8" x 12' 8" x 8' 5" {LxWxH}
I've talked to three people. Two of them said it's too small for 7.1 and the third said it's not, and maybe put the side speakers in the ceiling for more separation.
I guess that's Question #1. 7.1 or 5.1?
I'm going to have an entertainment center built and cover the openings with speaker mesh doors. This is happening because I have to hide my water main behind the right cavity. If that were a closet I would have no good spot to put an in wall speaker, so I decided to build the entertainment center.
Question #2. Is 15" deep enough?
Question #3. How high should the middle part be? Is there an issue with how high my center channel will be if I put it in there and it's about 6' to my first row of couches?
Question #4 Riser depth:
I can't for the life of me figure out how deep my riser should be. I got such a good deal on the couches that I actually bought them before I had a theater! The back row if four power recliners in a curve. The riser will be 14" high. It's hard to figure out because I want to avoid pushing my front couch too close to the screen and yet I want to avoid making my riser too small. But since they're curved, only the corners of the end recliners stick out much farther than the rest, and the couch in front is an 8' long three seater, so those corners sticking out might not be a problem anyway....argh! I'm thinking about a 6' 3" riser, which means that when fully reclined, the corners of the end chairs will hang out way over the front of the riser...but who reclines all the way to watch a movie!? I can't figure it out! Here's the size of the couches...
And here's the space....
(the water line was moved to the right)
Thanks for any ideas or suggestions you might have!
