Help to choose soundcard.
198 Views 1 Reply 2 Participants Last post by  stanger89
Heylo.
I've over the last couple of weeks considered buyin' a new soundcard for my HTPC and expand my Stereo to Surround.
As for now my setup consist of
Harman Kardon 1.0 (7.1 Preamp - but no decoders.)
TacT SDA2175 (For Fronts)
TacT SDA2175 (For rears)
4xInfinity Renaissance 90
I am only going' for 4.0 and what i need to know is if it is possible send the center signal to my fronts just as good as my former Yamaha DSP-A1?
Furthermore, i need to know which cards that can decode both dts and ac3 or if some sort of software decode it just as good?
My budget is about the ~300$.
Status
Not open for further replies.
1 - 2 of 2 Posts
What I would do, with that budget, is Theatertek 2 with the advanced audio pack, and an M-Audio Revolution, Delta 410, or 1010LT. You would configure Theatertek (or more specifically the nVidia decoders it uses) for 4.0 speaker setup.
1 - 2 of 2 Posts
Status
