I was all set to buy the new Panny AE700, when a dealer friend has said that he is able to do me a deal on a brand new Screenplay 5700. Effectively I'd be getting the 5700 for only around US$400 more than the Panny, and now I'm torn!
I understand the pq on the 5700 is very good and, even with the contrast of the Panny being as good as it is, the 5700 is still better. However, if I go with the 5700 I'm a bit worried that the drop in screen resolution will be a problem.
I explained that I have seen rainbows in the past with some DLP's (although they've never caused any problems - I've just noticed them) so he's happy to let me try the 5700 out at home to make sure I'm happy.
Has anyone here seen both of these projectors? I'd love to hear from you if you have, or even if you've seen similar models I'd like to hear any comments you have.
In NZ we don't have any HD broadcasts so HD really isn't an issue (althought I'd still like to try out the WMVHD discs). The majority of viewing will be TV & DVD.
BTW....main unit driving this will be a HTPC.
Anyone?
Anyone?
