Status
Not open for further replies.
1 - 8 of 8 Posts
Hey All,
I just bought the Showstopper 2000 and I am setting it up with Toshiba DST3000 HDTV DirecTV STB. I am using IR Blaster which I am certain is positioned correctly. I started with the Toshiba code - no good. Tried every other Satellite code - no good. Called Panasonic - they did not know about the DST3000. Panasonic called Replay TV who called Toshiba who said they would get back to them sometime with the code!!!
I am sure I cannot be the first person to try this combination. Any help greatly appreciated.
Andrew
Premium Member
Did you try the Hughes codes? That is who designed the box and the Hughes remote I have controls the DST3000. It should work.
Discussion Starter · #3 ·
Thanks for the response. I put in the Hughes code but with no success. Any other suggestions gratefully received.
Andrew
Premium Member
Did you try calling Panasonic or Replay? I can't think of what other codes to use, I know that the box uses Hughes codes. I have a DST3000 and a Hughes E45 receiver that use the same remote. I am not sure if Hughes uses different codes for their other models. The showstopper I have works with the Hughes E45, but I use the serial connection. Something they forgot to include on the HD boxes(except for sony).
Discussion Starter · #6 ·
Hey ilkevinli,
Thanks for responding. I have put in code 0749 which according to the manual is the Hughes stellite code. I have the adhesive sensor attached to the DST 3000 center by the green on/off light. My showstopper is the PV-HS2000. Still no success - it tells me there is no video signal and I cannot control the DST 3000. I have tried both composite and s video connections.
Any other thoughts. Still no reply from Panasonic.
Andrew
Discussion Starter · #8 ·
Yes, I have the correct video input. The setup forces you to do that before you input the code. I guess I am stuck until I get the correct code. The only other possibility I can think of is that the IR blaster sensors are faulty??
Thanks again for your help.
Andrew
1 - 8 of 8 Posts
Status
