Status
Not open for further replies.
1 - 1 of 1 Posts
Help! I am experiencing picture quality issues on my PRO510 when watching SD DISH 6000. Trying to figure out if it's the TV or the Dish. I can't pinpoint specific stations or shows that cause it. Specifically, there is a loss of definition and color gradation, especially during closeups. Sometimes a line will come and go across part of the face. (Sorry, I'm sure there's a technical term for this, but I don't know it!) Pic quality is great in HD and DVD.
I have changed inputs and exchanged the receiver (through DISH). I think I turned every setting off on the 510. Reset the convergence. Nothing has worked.
Signal strength is always between 80-110.
While the cable run from the dish to the receiver is long, I don't think it is 100 ft. (If the distance IS too long, what effect does it have on the picture?)
Are there any settings on the 510 that could cause this?
Thanks in advance for your help with this.
1 - 1 of 1 Posts
Status
