Status
Not open for further replies.
1 - 2 of 2 Posts
I am working designing a budget HTPC. Here is the list of components I have so far.
Case Antec Overture II Like Antec build quality
Mother Board ASUS K8N4-E Deluxe PCI-E video, NFORCE
CPU AMD Sempron 64 2600+
RAM crucial 512 mb
Video Card Aopen 6600 Fanless
Tuner Card H. PVR-150 MCE
Hard Drive Samsung 160gb
Optical Drive Lite On DVD Writer
OS MC 2005 w/remote
I am mainly interested in easy access to my digital music collection and PVR functions. I will also use for DVD playback. I was also thinking of using it for OTA HDTV if the TV I buy does not have a built in tuner. I currently have a basic SDTV with composite input but will upgrade TV next, most likely a 30 to 34 inch widescreen tube HDTV with HDMI input. I am confused about what to get for a video card. From what I have read a 6600 is the minimum for MCE 2005 for HDTV output. What I don’t understand is why. If I use a lesser 5000 series card with a DVI to HDMI cable why wouldn’t I be able to send a 720P of 1080I signal to the HDTV. Any help would be appreciated and any thoughts on my setup would be welcome.
Banned
MCE uses VMR9 render only to display video
so the video card requirements are higher than an app that does not
but the benefit is a smoother, more fluid like picture, with better color detail
I would keep the 6600 and if the one you choose does not have component output (HDTVout)
I would look for one that does
and use it instead of DVI to HDMI
especially if you plan to buy a HD DVD/Blu ray player in the near future as well
which require using HDMI (and it is unlikely you will be able to upgrade your HTPC to playback HD resolution DVDs)
one more, since you are considering a CRT based HDTV, component vs HDMI should made little to no difference
1 - 2 of 2 Posts
Status
