Status
Not open for further replies.
1 - 2 of 2 Posts
Hi,
I am french, so I hope i'll be clear...
I use a VPH-1252 with an iScan Pro.
After modifying my projetor's fans I didn't see that one turns off. During a movie I smell burned electronic and see a ghosting on the red picture. This does not affect green and blue.
I tried S-vidéo and it works fine, so it seems the problem appears only when doubling.
I tried another RGBHV input card and the problem is the same, so the frie element is on another board.
The ghosting looks like that (look at the right of the characters):
http://vlheur.free.fr/echo.jpg
Any idea where is the burned element ??? (I have a voltmeter)
Vincent
Discussion Starter · #2 ·
Problem solved !!! A stupid problem of connexion. The smell put me on the wrong way.
1 - 2 of 2 Posts
Status
