1 - 5 of 5 Posts
Alll,
What is the difference in glare between VT25 and S2???
I am looking to upgrade to 65" for my TV. I have the TV against a back wall in a room of windows. So, no direct sunlight hits the TV but the room has a lot of natural light. (diagram below)
W= window
---TV---
W-----W
W-----W
W-----W
W-----W
Should I just give up on Plasma all together?
Banned
I had the 65S2 and although there was some obvious glare when the set was powered off I thought it was more than acceptable when the unit was turned on. It was in a well lit room with windows including an extremely bright chandelier.
Banned
Originally Posted by mkedda /forum/post/19569756
You said you had it. Was something wrong with the set? Did you get rid of it?
Responded to your PM.
Originally Posted by neoshredder27 /forum/post/19569784
S2 is fine as long as no direct sunlight hits it. It's not great with light but does a decent job. VT25 is way ahead of the S2 and the price shows it. lol
I agree with neoshredder. I never had a problem with glare per say but yeah it's not the brightest tv in the world. There were sometimes I felt the need to jack up the brightness/contrast a bit mostly because I always watch tv with a lot of lights on. The majority of the time it was fine.
1 - 5 of 5 Posts
