hi all... ok, my beloved LT240 still has not been properly mounted, it sits on the cardboard box it arrived in for over a month now, and i am unsure what direction to go in for my mounting needs... heres the situation..:
if you examine the image below, you will see where i am wanting to mount the unit, above the couch and window... the ceiling has an odd slant right there, and it appears that my install will require not just the mount itself, but some sort of 'extension pole' that will allow the projector to be pushed forward a bit, and then lowered to sit in front of the window glass itself, perhaps 14 centimeters lower than the top of the window for optimum throw against our wall/screen... so the normal Peerless mount will not work i don't think..?
is there a 'turnkey' solution to my needs, that allows these sort of positions? i'd really love to get this mounted sometime soon, but have no idea what i will need to purchase to get this done... is there a common mounting system that can meet my needs, or any other resource someone can direct me towards? thanks to you all in advance..!
http://twash.com/temp/couch_view.jpg
