Greets all!
Long story short, I came into a little money over the X-mas holiday (actually hit a small jackpot in Vegas, no joke!) and I'm thinking about jumping on a projector upgrade (especially since this next year money will be really tight!).
I currently have an InFocus DLP 1024X768 business projector on an old 86" 4:3 Da-lite screen, with an HTPC via 30' DVI cable as my source.
I'm seeing the HC5500 at about $1950 with $500 rebate or $300 rebate with free extra bulb.
I'm very DIY and have a small garage workshop. So I was considering building a 2.40:1 screen and saving up for an Anamorphic lens....but truth be told, I'm in a bit over my head and I really don't understand how to figure if this combination is even possible.
Here is a sketch of my room I whipped together in MS Paint, and quick shot of my room:
I have a short attic above the livingroom, so I can easily run wiring for the projector up there. I'm not really concerned with where the projector winds up, as long as it doesn't hang down too low....and from what I've read, the projector typically winds up over the seating position (which the online calculator confirmed for me at about 18'). The room is 95% light controlled with (overpriced) blackout drapes, and I'm considering painting the ceiling a darker color and/or treating it with dark colored cloth covered acoustic insulation.
I'm hoping for a 50"-54" tall screen at 2.40:1 which would give me a width of ~120"-129.6"
Can you all offer some suggestions as to if I'm on the right track here. Problems I may have, and what screen options I should consider? What anamorphic lens would work with this setup? I'm thinking I want a white or light gray laminate screen...but I'm not even sure I can get this projector to work the way I want to with my (daydreamed) setup.
Sorry if this all sounds rushed...but the rebate on the projector ends tomorrow, so I need to make my plans today and put the order in tomorrow at the latest!
Any and all suggestions are greatly appreciated!
