I am trying to use the emitters with the MRF-100 RF base station to control
Tivo in another room and a Lutron Grafik Eye that is out of line-of-sight. The base station correctly "floods" the cabinent and will control the Lutron if you physically point the base at the box. However, the plug-in flashers that we have running about 40 or so feet over Cat 5e are not working. We tested a flasher that hadn't been spliced and it worked fine. Is there a reason the flasher cables cannot be spliced?
Any help appreciated!
