Hey guys whats up.
I'm looking for a portable speaker setup to play music. I host a handful of backyard parties during the summer & organize a few others at the beach and park. I moved recently and left behind a 4 speaker JBL setup I had put in the backyard that sounded great- clear, rich sound and good bass that filled the backyard with sound from each corner. I need a new setup but decided I want consolidate to a single portable battery powered setup to play off of my phone or laptop that I can use in the backyard & also on the go. Basically I’m looking for a setup that will produce very crisp sound, deep bass and can be turned up loud without distorting. It will often be used to play dance music & deep house. The most important thing is for the sound to be crisp and full. I try to get music in FLAC whenever possible and play from an SD card when possible.
I looked briefly and found many BT & USB/ SD Card enabled PA speakers that seem to be exactly what I’m looking for at around the $200 price range. Only issue is that most look to only go up to 100 watts., which is expected as it would either be under-powered, too large or battery drain would be too quick.
Are there actually any 600 watt portable setups or maybe a separate portable battery pack that can be purchased to power a 600 watt speaker on the go? If not, are there any portable setups with built-in batteries that would likely be enough for what I'm looking for ?
If anyone could point me in the direction of a good speaker for this I would appreciate it
