For the moment my brain is at super saturate and I'm a bit confused by the calculator on PJ Central. When switching between 16:9 & 2.39:1 the throw range is longer, I assume this is not using an anamorphic lens? When using a CIH anamorphic lens setup the throw range for 2.39:1 would be the same as that of the 16:9 w/out?
Also in this particular installation we are just about at the minimum throw and according to the Panamorph site the UH480 lens will work but needs a curved screen. Looking at the Schneider Cine-Digitar Anamorphic 1.33x M Lens it appears that this would also be an option but its not clear to me and if it is applicable:
1. It would also require a curved screen?
2. Is it a better optic than the Panamorph?
