Status
Not open for further replies.
1 - 1 of 1 Posts
I have pulled the trigger and my AE100 is on its way. Thanks to all of the information on this forum, I have decided to keep my interlaced DVD player and use the iscan processor. So I have two questions for you folks:
1) I can get the iscan v2 for $400 or the pro for $640. Is there enough of a difference in function/quality to jump up to the pro?
2) Regardless of the answer to question #1, what is the spec for the VGA cable? (M-M 15 pin? M-F? 15 pin?)
Thanks for all of your help.
David
1 - 1 of 1 Posts
Status
