1 - 2 of 2 Posts
I have the WD TV hooked up to an Acer LCD Monitor X213W.
the monitor works fine with the PS3 when set to 720p - though not listed amognst supported resolutions (see below) - nonetheless it works fine (though doesn't work with 1080i/p). However it doesn't show anything when hooked up to the WD TV. I've even set the WDTV (via hooking up to another monitor) to output only 720p and still nada.
Any idea?
Also in case I'm SOL with this, what I am looking for is something to play my high def AVCHD .ts files from my Hauppaugge HD PVR, ideally something that can play them via a network connection would be great, as I wouldn't have to transfer them to an external hard drive as I have to with the WD TV.
any ideas?
Resolutions supported by monitor
640*[email protected]
800*[email protected]
1024*[email protected]
1152*[email protected]
1280*[email protected]
[email protected]
1600*[email protected]
1360*[email protected]
1440*900(Red)@60Hz
1440*[email protected]
1680*[email protected]
[email protected]
832*[email protected]
I am not the expert but with HDMI to DVI reduction in 720p
should be working this ACER dont have 1080i/p support
check the native resolution in ACER DATAsheet PDF on ACER homepage
but 720p should working
did you try
http://www.eforcity.com/hdmi-dvi-cab...FQsh3godlRZenA
try find cheaper one but not too cheap
LQchina products can decrease quality of signal.
I am also interested howto you will resolve this problem
send me a private message please
thx
1 - 2 of 2 Posts
