Status
Not open for further replies.
1 - 2 of 2 Posts
· Registered
I’m a bit concerned. I have a Radio Shack double bow tie antenna on the second floor of my house with a 75 ohm line run down from the antenna to a Mitsubishi WS-65909 (built in HD OTA tuner). I recently purchased and installed a Winegard AP8703 19dB pre-amp (300 ohm in to 75 ohm out). I then got the UPN digital station and the WADL digital station. I have been using it for about two days now with no problems. It worked late last night as well. However, when I tuned into any digital station today there is a loud static or clicking noise that eventually just stops after about 5-10 seconds. The noise can be turned down and muted, if that helps. Audio from my cable is fine. I have tried different cables and not using the pre-amp and the noise still persists. Does anyone know what may be the problem?
-Andrew
1 - 2 of 2 Posts
Status
