Status
Not open for further replies.
1 - 3 of 3 Posts
Newbie here. I purchased some firehawk material through jason at AVS (thanks again)
but I'm not 100% sure which side to use to project on. The smooth side or the rougher side with more glitter. Forgive a newbie, just don't want to end up using the wrong side after spending the cash. Thanks in advance for your replys.
Discussion Starter · #3 ·
Thanks Utopia,
I'm actually using a panasonic AE100 with it. I've had the projector for the last seven months and was using a blackout cloth DIY screen and wanted to upgrade. I figured the screen would be a keeper even when I upgraded to a better projector down the road.
It looks great by the way. Thanks again.
1 - 3 of 3 Posts
Status
