1 - 9 of 9 Posts
Hi,
been wrestling my new htpc/desktop for while now to have decent playback of my 1080p mkv's. The videos playback is grainy and doesnt' look crisp. My 1080i digital cable looks better than these. I've been using makemkv to create all my mkv from BR discs. I think i've wrestled with every codec pack there is with no luck (cccp/k-lite/coreav to name a few)
Hardware:
i7 -860
ati 5770 - hdmi out
4GB ram
Samsung 37a550
Any advise would be helpful
check your ATI graphics driver settings.
I noticed the 10.11 drivers doing crappy things.. Turn off most all of that crap, and see how it looks.
Discussion Starter · #3 ·
Which settings should i be checking? All are default right now and using 10.7 ccc
Discussion Starter · #5 ·
Originally Posted by Mrkazador /forum/post/19633387
What is the average bitrate of your encode?
General
Complete name : E:\\Movies\\Iron_Man_2\ itle01.mkv
Format : Matroska
File size : 27.3 GiB
Duration : 2h 4mn
Overall bit rate : 31.4 Mbps
Encoded date : UTC 2010-12-11 19:56:08
Writing application : MakeMKV v1.6.2 win(x64-release)
Writing library : libmakemkv v1.6.2 (0.7.7/0.8.1) win(x64-release)
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Container [email protected]
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 4mn
Bit rate mode : Variable
Bit rate : 29.3 Mbps
Maximum bit rate : 32.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.589
Stream size : 25.5 GiB (93%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 2h 4mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Stream size : 1.31 GiB (5%)
Title : 3/2+1
Language : English
Several things...
You first need to figure out if it is your encoding software or decoding software. I hightly doubt that it is your graphics drivers. I would suspect that your encoding software is the culprit. You might want to read up other options...megui/avisynth as examples. Try downloading some 1080p mkv samples that others have encoded.
Discussion Starter · #8 ·
Originally Posted by Mrkazador /forum/post/19633417
Ok, so this is a remux... Check CCC and disable any video processing like zryder suggested. Also, what media player are you using?
typically WMP but i get the same results with xmbc, mpc, and wmc
1 - 9 of 9 Posts
