I have been looking at the RCA 27 inch HDTV Flat CRT tube monitor television at Walmart for $294 for my mother. Even though it has an analog tuner, it also has progressive scan and other high end features. The remote is a standard RCA that looks easy enough for finding the on-off button, channel up and channel down. It is a new set, only the 32F750T version shows up on the RCA website. But, except for size and weight, the specs are the same for the two sets. Some specs: INVAR Shadow Mask, Progressive Scan, Scan Rate Converter TruScan Digital Realityâ„¢, Digtial 3-Line Comb Filter, HD Component Input (SYNCROSCANâ„¢),
DVI Input with HDCP, Universal 3-Device Remote.3:2 Reverse Pull Down, Adjustable Color Temp, Auto Color Balance (AKB), Dynamic Color Stretch Circuitry, Scan Velocity Modulation - SVM,Contrast Expand (B&W Stretch),Format Control,Automatic Letterbox Detection, Wide Band Video Amplifier
