I just got the 3.0 software a couple of days ago, and it's great, but I have 2 questions....the first, my cable company requires me to use a cable box to change channels. With the 3.0 setup, I chose the correct model (I have a Scientific Atlanta model 8600STNN), and found the remote code that would allow the blaster to control the box. Before this software update, I was able to modify the code for my cable box so it would send "09" instead of just 9, where it would then wait about 10secs for another #, and then finally switch to 09. How do I set this up in 3.0?
I also successfully manually recorded a program. Once recorded, it showed up on the recorded program screen, but my ? is, once you have set the rptv to manually record a program, how do you review the settings? Is there a page that just lists the manual recordings?
