1 - 4 of 4 Posts
I've got a 5040 unit with an Ethernet problem.
When I connect up ethernet to the RTV, the green lights light up and even blink a little, but it can not see the network. It won't grab a DHCP address, or take a manual address. I normally have it with a static IP, and I could not ping it, even connected direct with a crossover cable.
I searched the forum, and from what I can tell, the network lights don't normally light if the Ethernet jock is bad. Is this true?
Any suggestions on how to make this work?
Sure, I can go back to dial up, but I've become accustom to streaming between my 5000 units. Any suggestions? Is my port dead?
Make sure you do the basics like connecting the replaytv directly to the cable modem after rebooting them both. Doing so cuts out a lot of problems that can happen in the router. If you can contact the mother ship that way you know the problem probably lies in router settings.
1 - 4 of 4 Posts
