Hi,
I have managed to pixel
[email protected] 60hz via Dvi but i am unsuccessfully trying to pixel map @ 50hz for UK pal source material, using the vga input fed from a HTPC.
Using a Geforce 6600gt i get two options close to the pixel count of the phd8 but not at the exact value required.
The two options available are 1360x768 and 1368x768, when i try powerstrip to produce the required
[email protected] it keeps defaulting to 60hz.
When i try the other two i can only get a noise free picture by having the size set a few pixels short either side, so it won't fully fit the screen.
I am using the mapping pictures/utilities without success as i seem to loose 1 edge line off the nokia mapping picture and i have a lot of scan noise that i can't reduce enough for it to become clean.
Anyone successfully mapped a 50phd8 using a PC of sorts and @50hz?
I could possibly try scaler settings if someone could post there's, for using 50hz setting for VGA.
Any help would be appreciated, please.
