Status
Not open for further replies.
1 - 2 of 2 Posts
Ok, I have a 5.1 system right now and am planing on moving them to my dedicated home theater upstairs with a projector and everything. So right now I have 4 B&W Dm 602 S2 and the matching center channel, and a B&W sub. So I would like to go 7.1 but will need 2 more speakers for my sides. What do you suggest I do, will the DS6 S3 work?
Also for recievers what about the Denon 3803? I don't want to spend a lot but if there is somthing beter for a little more I would be up for that also. Thanks,
Ryan
I would opt for a pair of used 602 S2's via the used market or ebay.
I recently did something similar. I have 604s as my mains, but had Kef rears. I bought a pair of 601 S1's for the rear, and am looking to buy a CC6 S1 for the center (I currently have a Klipsch).
While the differences may be minimal, and think the best timbral match would be with the same series of speakers.
BGL
1 - 2 of 2 Posts
Status
