Its probably been a while since anyone here has touched a Fujitsu, but I figured I'd ask.
I've got a P50XTA51UB that I've been trying to dial in via ChromaPure V2/Chroma 5Pro. Source is an Oppo BDP-83 NuForce edition. Couldn't get a consistent gamma response (no matter what picture mode or combination of brightness/contrast/drive settings I used) so I put an AV Foundry Video EQ Pro into the signal path, which has worked wonders for the gamma and greyscale (though I still have a little more tweaking to do).
Biggest issue is red. I just can't seem to get red (and in turn magenta) to track correctly. Saturation appears to be the key problem, with both red and magenta being undersaturated. Anyone know if these Fujitsus can even deliver a properly saturated red/magenta or am I stuck with the very slight pinkish hue? If they can do it, any suggestions for what settings to modify. The built-in CMS controls are pretty advanced, maybe I'm just using them wrong. I'm also wondering if I should be adjusting the main color control to help out with red.
I've attached my latest calibration report.
